Hello
Does anyone know if there is a HD upgrade for the DTV on the mark BV7?
Any advice is welcome.
Carl
Yes it’s 1089P, but there are no HD channels when I scan the DTV channels ... Apple TV and other inputs are full HD, so I assumed that the DTV is not HD.
I may be wrong?
Yes, although I’m it the first owner, it was supplied by B&O Winchester in 2010.
Hmmm, maybe my aerial is not up to scratch.
Thanks you are both correct, the mk4 only has DVB T and not T2, which is what is required for HD reception.
Looking at my menu, I have only a few items listed in the PUC menu, so I would need to get B&O service folks in to make the Beo4 remote work, and unless I misunderstand?
That is correct!
Find the box of your choise and ask the dealer (or here) for a (well) working PUC entry.
When you setup/install the box, first disable both tuners in the menu - then you will be able to assign the TV button on the Beo4 to activate the used input port.
N.B. If not already installed be sure to get the entry for the ATV box (and/or others) - even if you don’t need those now, it is nice to have, if you at some point should want to sell the BV7.
Enjoy.
One last question... doesn’t the BV 7 require the B&O service tool to add / remove PUC entries?
Carlos09:One last question... doesn’t the BV 7 require the B&O service tool to add / remove PUC entries?
