http://www.ebay.co.uk/itm/BANG-OLUFSEN-BEOGRAM-CD-3500-4500-LID-COVER-SIMIL-WOOD-LETTORE-CD-PLAYER-/121020715586?pt=Piatti_e_Lettori_CD&hash=item1c2d659242
Maybe it really doesn't fit in the style? They have other intresting stuff also, like marmorized Philips CD...
Not for me and I don't like the particular wood pattern, but IMHO it looks at least half decent. If wood & glass had ever been simultaneously in fashion, something like this might well have been produced.
--mika
Isn't it just a plastic film cover? As long as you put it on properly, it should be OK but 59 Euro seems quite expensive! I imagine carbon fibre etc would also be possible.
Peter
Actually quite pretty! It's as if B&O kept the original 70's Beomaster design aesthetic instead of going down the aluminum path.
Jeff
Why not, looks pretty neat!
Brengen & Ophalen
Peter: Isn't it just a plastic film cover? As long as you put it on properly, it should be OK but 59 Euro seems quite expensive! I imagine carbon fibre etc would also be possible.
Good eye! Definitely laminate not veneer.
Aaaa, not for me, anyway. I think wood is ok in more "Box"models like 4000 series, in these with glass panels.... Not for me.
It still looks like something you throw in your fireplace...
I don't mind plastic, if its design follows function. But I don't like so called "simil wood". I am glad that B & O shows plastic when it is used (like BeoSound 8) and does not hide it under more plastic.
