7.1 surround query
This post has 3 Replies | 2 Followers
blidge
Posts 11
blidge Posted: Thu, Mar 15 2012 7:03 PM
First time poster and new to the world of B&O so go gently with me.
I'm currently in the process of putting together my surround sound setup and have a speaker dilemma. I'm using the following:
Samsung TV with matching soundbar being used as centre channel via aux input
Onkyo 7.1 AV amp
Grundig Audiorama 9000 fronts
And now the dilemma. For my surround speakers I have a pair of Beovox 3000 and a pair of Beolab 4000. Which should I use as the rear surrounds (behind the listener) and which as the side rear surround (to each side of the listener)? In a 7.1 setup is the rear or side rear utilised more as if there is definite bias towards one I would guess I should utilise the better speakers there? Which then opens the debate as to which is the better speaker?
I'd welcome any thoughts, advice and opinions.
DMacri
United States
Posts 881
DMacri replied on Mon, Mar 19 2012 10:17 PM
I would use the better sounding speakers as the side surround since they may be used more often. I'm not familiar with the sound capability of the BL4000, but I've owned a pair of BeoVox 4500s and was impressed with their performance.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Søren Mexico
Mexico City
Posts 6,411
If your Bvox 3000 are flat panel, I would use the BL 4000 as side and the Bvox as back, the BL 4000 is the better speaker.
If your Bvox are the old box type, you will have to decide which one is the better.
beojeff
USA
Posts 2,012
beojeff replied on Tue, Mar 20 2012 1:28 AM
I have both the Beovox 3000 and Beolab 4000 speakers. The Beolab 4000 speakers far, far outperform the Beovox 3000 speakers. Unless your surround processor is matrixing all sound, including 5.1, to 7.1, the side surrounds speakers will be used more than the rear speakers. Thus, it might be better to use the 4000s as the side surrounds.
Page 1 of 1 (4 items) | RSS
