Hi guys,
just exchanged all belts on a beocord 7000.
everything works fine.
it’s just running to slow (I would guess on 95% speed).
so the songs are only usable for turtle watching 😉
is there anything where the speed can be adjusted? Or us it still a cleaning and lubricants problem?
best regards
69er
Did you fit correct belts or some you got off Ebay?
Hi Dillen,
i ordered through ebay, but from a supplier where i ordered dozens of other belts and evrything was alright.
Do you think it´s because of the belts?
Best regards
