MX6000 vertical collapse?
This post has 1 Reply | 0 Followers
djh_
Posts 5
djh_ Posted: Sun, Apr 11 2021 9:32 AM
Hi again,
Sorry if this is effectively a double post: my previous issue was that the set wouldn't turn on, but now it does and has a new problem, which I figured deserved a new post title.
Backstory: the set worked when I bought it but had quite bad geometry issues, primarily the bottom of the picture curling slightly to the left and some very noticeable S-correction 'squashing' on the left and right sides. Then one day the set simply wouldn't come out of standby.
I replaced pretty much all the caps on the mainboard, and now the set does come on, with sound, etc, but the picture is:
Is this vertical collapse? What should I go looking for when I open it back up?
djh_
Posts 5
djh_ replied on Wed, Apr 14 2021 1:30 AM
Solved it myself in the end. There was a broken trace in the vertical deflection circuit, but the distance to the next pad was so small I just jumped it with the cap leg. TV's back in business and looking great thanks to the new caps.
Page 1 of 1 (2 items) | RSS
