Hello
I cant seem to find any information about factory resetting a Beovision 10 television, I am having problems adding an Apple TV 3 gen. to DTV, the TV seems to be configured for "normal" television channelse on DTV.
It was no problem adding an Apple TV to my second Beovision 10.
How do I factory reset a Beovision 10?
It should be possible to disable the digital tuner on the BV10-32.
This would give you the option of assigning another source (e.g. your ATV box) to the DTV button on the remote (in the setup menu of the input).
If you still need the digital tuner, you might be able to disable the analog tuner and this way free the TV command....which then could be used for the digital tuner.
A factory reset won’t help you.
