Most functions can be done using a Beolink 1000 but some programming etc. can only be done on the MCP.
So, the simple addition of the Beolink 1000 would do most of it?
For example, I would like to be able to do at least the following:
1). Change volume,
2). Select the component to be played, and
3). Be able to (via IR) remotely affect these things.
dan
Edgy01: So, the simple addition of the Beolink 1000 would do most of it? For example, I would like to be able to do at least the following: 1). Change volume, 2). Select the component to be played, and 3). Be able to (via IR) remotely affect these things. dan
Yes, a BL1000 would be fine for day to day operation, including the things you have listed above.
