Beosound Stage with LG Oled G1
This post has 3 Replies | 0 Followers
Polderboy
Posts 2
Polderboy Posted: Sun, Apr 18 2021 1:13 PM
I have Beosound Stage connected through HDMI arc to my LG OLED77G1RLA and i cannot adjust the volume with the Beoremote One or the Original LG remote.
The soundoutput on my TV is set on HDMI-Arc and the sound does come out of the Beosound stage, but the soundlevel keeps standing on one value. No matter what i try. I only can adjust the Volume with the Bang & Olufsen app.
Is this a known issue or do i do something wrong?
I hope someone can help me.
andybandy
Posts 164
andybandy replied on Sun, Apr 18 2021 4:17 PM
Hi, go to you local B&O dealer and Get they open for a new software to Stage.
Its not update it self, need to promt a new software to the specific serial number on your stage.
your software should be: 2.4.43389.93169778
Mikipidia
Posts 2,169
Mikipidia replied on Sun, Apr 18 2021 4:28 PM
Is the ethernet cable connected between the two? Just to be sure that that’s the case too.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
BeoMegaMan
Posts 601
C1 panels require service update to Stage via ethernet. Call your dealer to issue the patch to the product.
Ah, you know... A little B&O here, a little there
Page 1 of 1 (4 items) | RSS
