My recently acquired Beogram 7000 is running about a 1/4 tone fast. As I have perfect pitch, this can at times be exceedingly annoying. Is there any way I can correct this? Ideas gratefully received.
Can't you set the correct speed using the trimmers?If the speed setting trimmers have no effect, they must be replaced.
Thanks for the response, Martin.
I probably could if I knew where the trimmers are, and how to adjust them!
Mark
I can't find the service manual for the 7000 - only the one for all the other tangential arm Beograms - is the 7000 the same? (I presume so, but I won't start any work until I am sure.)
It suggests adjusting R32 and R34.
However, I would really appreciate advice from someone who has done this before:
1) Where are these (I can search through all the diagrams, but if someone knows it would be much quicker!)?
2) What is the easiest way to get to them (i.e. what do I have to take apart, in what order?).
Any help/suggestions gratefully received.
Thanks!
Accessible from below with a fairly long but narrow flat-bladed screwdriver (Beograms front left corner out over a table edge).Same for all Type 59xx decks.
