I have BV8 master with BC2 with a DAB radio and a Beosound 9000 in a link room. When I press radio on the remote I can only access the radio on the beosound 9000. I use the beosound 9000 for analogue radio and playing Cd's. I use the Beocentre 2 for playing DVD's. Even when I press radio on the BC2 front panel it registers on the BC2 display but nothing happens and there is no sound output.
Is anyone able to help me to be able to play the DAB radio of the BC2
Many thanks
paddy2042
Does it display the station but there's no sound?
I'm afraid I have read that Australia is using DAB+, not DAB.
B&O's BC2's had DAB if so (there were ones without DAB as well)
And there's a very rare version having DAB+ which module is no more availabe since a long time :-(
Did it ever work before?
Yes it worked until I connected the Beosound 9000 and all stations are tuned correctly. I think the problem was that there were two radios: one in the Beosound 9000 and one in the Beocentre 2. I think I had to disconnect something so that the system would not try to turn both on when I pressed Radio on the Beo4. I also think there is a problem as both the Beosound 9000 in the link room plays Cd's and so does the Beocentre 2 and so there was a conflict there. This was setup so long ago I have forgotten the exact configuration.
I hope this makes sense to someone.
