Beovision MX4000 can not adjust contrast with RGB SCART
kiario
Posts 8
kiario Posted: Tue, Feb 5 2013 9:32 PM
Hello,
I am using this TV for gaming and can not find out how to adjust contrast, color etc when connected with SCART RGB. I get the menu but it wont store the values.
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Feb 5 2013 10:19 PM
You should be able to adjust contrast and brightness as with any source. If those settings won't store, you're probably just not doing it right. You need to exit the menu with GO if you have a Beo4 version of the TV (I believe it's STORE with the older Beolink 1000 versions).
Note that when you call up the menu to do the adjustments, the visible picture changes into what it would look like from a composite input. The brightness, contrast and sharpness will look quite a bit different from what they will be once you exit the menu into RGB mode again.
Colour saturation cannot be adjusted with RGB (because it would require the TV to transcode the RGB input first into something else, then do the processing for the adjustment, then back to RGB - and they just don't include the circuitry for that).
--mika
kiario
Posts 8
kiario replied on Tue, Feb 5 2013 10:27 PM
Hello,
Ok, thanks for the info. I did the test with color so I though something was wrong.
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
