Drive wire for beogram 6500
cmsammy
Posts 84
cmsammy Posted: Tue, Feb 5 2013 10:36 PM
Can anyone help me to find a replacement drive wire for a beogram 6500. This has been playing up for a while, missing the record edge despite all attempts to adjust it, went to use it tonight and found the drive wire tangled all over the place. It seems to be intact but I wonder if it has stretched and therefore came off.
Any help appreciated,
Clive
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Feb 5 2013 10:43 PM
The wire is made of a sturdy material and I don't think it'll stretch, much if at all.
More likely the small plastic tab in the carriage that the wire attaches to has snapped off - quite common, and especially so if you have been messing about with the wire a lot trying to adjust it.
It's a relatively simple fix with an M3 bolt & nut (don't bother trying to reattach the original tab). I'm sure somebody will post a few links to past threads on the subject - I can't even find mine at the moment Big Smile
--mika
cmsammy
Posts 84
cmsammy replied on Tue, Feb 5 2013 10:49 PM
I did wonder if this had happened as both loops at the end are in tact.
I've searched and can't find the threads you mention, if someone could find them it would be really helpful.
cmsammy
Posts 84
cmsammy replied on Sat, Feb 16 2013 2:56 PM
OK, next step, seems I fix one problem and end up with a different one.
I've used the nut and bolt fix, worked a treat AND I have now got the arm to drop on the record edge.
BUT, it plays 1 - 2 tracks fine and then starts to jump, lift the arm and replace it carries on for another track. Seems that the arm is not moving across fast enough and the arm gets to far ahead and simply jumps out of the groove.
Any suggestions ?
cmsammy
Posts 84
cmsammy replied on Wed, Mar 27 2013 9:14 PM
Need to get this to the top of the list, I thought I'd fixed it but same thing happening.
I love this deck but it's now driving me nuts, help, PLEASE
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Mar 28 2013 6:25 AM
What broke this time ?
cmsammy
Posts 84
cmsammy replied on Thu, Mar 28 2013 8:02 AM
Hi Martin,
Nothing broke, it plays perfectly for 1 maybe 2 tracks if I'm lucky then starts jumping. If I lift it and put it back down it may play for another track then starts jumping again ???
Dillen
Posts 13,191
Dillen replied on Thu, Mar 28 2013 9:32 AM
Sounds like the carriage is no longer tracking correctly.
Probably the lamp and/or LDR in the tracking sensor assy.
Quite often the LDR, actually.
Page 1 of 1 (8 items) | RSS
