Waiting always for a limited edition of the Beolit 12 in black !! Hope Bang & Olufsen can read my wish ! ;-)
Isn't there a grey body black handle version out there that is the closest match already?
So if they were to have a black body Beolit 12 what color would you like the handles to be?
Certainly not grey I hope because that will be off....
It think there's a need for some color contrast to make the design work so if the grills are black as you wish then the special grill design with the black fabric underneath wouldn't pop. And then are is the matter of matching the color of the grill with the top and base of the BeoLit 12.
Perhaps they will have a complete overhaul in the color scheme in the next cycle change. I seriously think the Beolit 12 is here to stay but perhaps a Mk2 with better sound performance with less airplay dropouts? Apparently that has been a big concern - poor firmware and Wifi support.
And how about an alternative version of the A8 that is just as big but better built and sound with a design that doesn't look lacking without something mounted atop it?
Black with red fret and grey handle would look awesome!
For me, black with white fret and black handle will be amazing !
all black wouls look good
x:________________________
all black would look good
Agree with you Jonathan ! ;-)
hello kitty pink would be awesome
