Beosound 3200 and Beocenter 2.
hcs67
Denmark
Posts 7
hcs67 Posted: Mon, May 10 2021 11:18 AM
Hi :-)
  I have a Beosound 3200 in my kitchen and would like to install a Beocenter 2 in my livingroom.
The problem is that my kitchen and living room is connected, so I am afraid that my Beo4 will remote both systems simultaneously. Is it possible to program the systems, so I can assign a Beo4 remote for each system?
Thank you:
Rgds
Henrik Sommer
2 x Beosound 2300, Beosound 3200, Beolab 2500, 2 x Beolab 4000, Beolab Penta mk3.
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, May 10 2021 12:09 PM
If one of the two systems can be put in A.OPT 4 (where it only responds to LINK commands) then you should be able to set it up as you want, so that it will only respond to a remote set to permanent link mode.
But unfortunately I do not know if either BS3200 or BC2 can be put in A.OPT 4 - perhaps someone else on the forum does?  The BS3200 does not list A.OPT 4 as a possibility, but perhaps just give it a try.
If you do manage to get one on the systems to A.OPT 4, then you can hopefully set one of your Beo4s to permanent LINK mode as follows: (the Beo4 must be at least SW version 5.0)
Standby + List together
Press List till CONFIG appears
Enter 2002 , the display should read LINK ON
Press Exit
hcs67
Denmark
Posts 7
hcs67 replied on Wed, May 12 2021 10:04 PM
Thank you for the reply, I can’t make the option 4, work at my BS3200, my Beo4 is ver. 5.
Option 4 is not listed in the manual, for BS3200. But thank you for trying.
Rgds
Henrik
Page 1 of 1 (3 items) | RSS
