Beosound 9000 Mk 111
This post has 11 Replies | 1 Follower
mpc1507
Posts 16
mpc1507 Posted: Wed, May 12 2021 8:03 PM
I have a 9000 MK111 and I cleaned the laser, now the unit works perfectly except on disc 6 position when it is noisy running and clicking, all other positions ae silent running and working perfectly. any thoughts?
secondly when I press STOP on the BEO4 remote, I have 2 and the same issue, when in CD mode it pauses and displays pause as opposed to stop. I think this may be a remote programming issue.
any assistance greatly appreciated.
regards Martin
Bill Briscoe
Chicago, IL USA
Posts 165
The Beo4 remote operation is working correctly according to the BS9000 owners manual. Pressing stop will display Pause. That's how mine works.  You may notice that on the BS9000 keyboard there is no stop button, just pause.
You should run Testmodes 71 and 73 to synch up the end of travel of the sledge, that should resolve the issue.
Good luck!
Bill
mpc1507
Posts 16
mpc1507 replied on Thu, May 13 2021 10:39 AM
Bill, thanks a million, now how do I do what you suggested, I don't know how to access test mode.
regards Martin
mpc1507
Posts 16
mpc1507 replied on Thu, May 13 2021 2:04 PM
Bill, I got this completed and it worked perfectly, many thanks really appreciate your help..
Regards
Bill Briscoe
Chicago, IL USA
Posts 165
Hi Martin,
it's pretty simple but there a few steps involved. First make sure there is no dust, lint, spider in the well under #6, a can of compressed air carefully used can be useful. Make you you use a cloth or something suitable to cover the sledge before you shoot any air around.
remove BS9000 from power
add Shift command to Beo4 remote
  1. press Standby and List at same time, it will show Add?
  2. press Go
  3. press list until you see Shift appear
  4. press Go
  5. press CD
plug BS9000 back to power and quickly press Shift 90258 on the Beo4 remote
you should be in test mode now
press 71 and wait until it completes
press 73 and wait until it completes
press Standby to exit test mode and retry the unit.
If it still fails, enter test mode again (remove power, wait 30 sec, restore power and press Shift 90258, then 27 once you get back into test mode. Take note of any errors listed.
good luck, don't be frustrated if you don't get into test mode the first time. Just re-read the steps and be very deliberate.
Bill
Bill Briscoe
Chicago, IL USA
Posts 165
great news!
mpc1507
Posts 16
mpc1507 replied on Thu, May 13 2021 3:11 PM
actually I spoke too soon, no sound now and loud clicking on disk 4 & 6 only
mpc1507
Posts 16
mpc1507 replied on Thu, May 13 2021 6:01 PM
i repeated the process including cleaning the laser, all discs running silently in all positions just no sound. any thoughts
mpc1507
Posts 16
mpc1507 replied on Thu, May 13 2021 6:26 PM
forgot to mention headphones working fine.
Bill Briscoe
Chicago, IL USA
Posts 165
Any sound output on radio?  Are you using power link to speakers or masterlink?  If power link, have you tried re-seating the connector?  If masterlink, remove power from all ML devices, then re-seat the ML cables, and then restore power.
You could also try inserting and removing the headphone jack a few times, sometimes the reed that cuts out the speakers get stuck?
mpc1507
Posts 16
mpc1507 replied on Fri, May 14 2021 10:46 AM
Bill, the 3 amp fuse on my beolab2 plug had tripped out after I put everything back together, don't know why and it was the last thing I checked. everything perfect again. thanks for all your help.
Bill Briscoe
Chicago, IL USA
Posts 165
excellent news!
Page 1 of 1 (12 items) | RSS
