Want to adjust your doors on the Ouverture, Beocenters etc.?
REMOVE POWERCORD FROM THE MAINS FIRST!
The rest I don't have to tell you!
Brengen & Ophalen
Beofan53:This is what this forum is all about. Very helpful!
Bookmarked this thread, my Beosound 3000 makes a squeaky sound when opening the doors.
Top class instructions!
//Bo.A long list...
They always told me that this can be done only by experts but once you know how it is done there's nothing special to it. So why not showing it
Just added this post as a favourite. Great job with the tutorial!
Beocenter Overture | Beolink passive | CX100 | CX50
Hi
Many thanks again.....fab.
c.
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
This is a great posting. I just have one question. Once you have removed the screws how do you release the back cover ? - I don't want to force anything before I know what I'm doing. Thanks...
Hello Leslie,
May I ask you a question?
Which kind of screwdriver did you use yo unscrew A and others?
Thank you
Depending on age, it is crosshead or torx (T8 or T9)
