Does anyone have knowledge regarding use of asbestos in B&O radioes from the 1960's?
The only thing that springs to mind is the washer sometimes fitted for the dropper resistor.Any thing in particularly you think about?
As far as I recall, there are no asbestos in your Grand Prix 609 - if that's your worry.
I did some restoration to one of those years ago:https://archivedarchivedforum2.beoworld.org/forums/t/28435.aspx
Yeah, i was really worried about that - I don't think the one you worked on is the same exact model, but hopefully materials are identical.
