I would try the second option, but just remove the 2 cables on the left and then replace the top one.
I think there's a special cable insertion tool that will make re-connection easier - perhaps you have one?
Guy: I would try the second option, but just remove the 2 cables on the left and then replace the top one. I think there's a special cable insertion tool that will make re-connection easier - perhaps you have one?
Yes, I have the tool needed to connect the wires in the box.
Thank you for your input. This will be tomorrow’s project. I will decide then with way to follow. I guess I have nothing to loose to test number 2.
Honestly, if you are not experienced in working with a junction box, I would suggest the first option.
You don’t need the 20 cm - less will do, but be sure that the wires are seperated afterwards.
And.....be sure to disconnect all plugs from the devices, before you start.
If you are confident with the job, do as Guy suggested.
Personally I’d start from scratch (if there is enough cable) - it can be a fiddly job to replace one cable.
From the picture, the original job was well done....did you do it yourself?
Millemissen: Honestly, if you are not experienced in working with a junction box, I would suggest the first option. You don’t need the 20 cm - less will do, but be sure that the wires are seperated afterwards. And.....be sure to disconnect all plugs from the devices, before you start. If you are confident with the job, do as Guy suggested. Personally I’d start from scratch (if there is enough cable) - it can be a fiddly job to replace one cable. From the picture, the original job was well done....did you do it yourself? MM
Thank you! 😊 I’ve done it myself, and consider myself experienced in the noble art of master linking. As the system has expanded over the decades there’s a sophisticated net all over the house in the basement, the ground floor and the attic. But I never before had to remove any cables.
Update: I went with the second alternative and removed both cables on the left sides.
Before I started, the power was cut to all ML equipment and I removed all ML plugs. The wire holders in the junction box was cleared with a small screwdriver. I cut every wire a cm and connected them again with the special tool needed. It´s always a little nervous afterwards to test the system, but it worked as it should! Thanx for the advice!
The BS 9000 and the BL 8000´s deserved a new location. The old location was almost hidden behind a coach and some curtains. Now they got a new visible stage on a nice wall and just demands to be played. With some nice armchairs in front it´s now our listening place for music.. I´m now on the look out for a nice Beogram to add.
It´s really great to be able to move around the different speakers and systems, and still having them connected.
