Beocenter AV5 tv cd-i won’t work
This post has 12 Replies | 0 Followers
JamesSamuel
Netherlands
Posts 51
JamesSamuel Posted: Sat, May 15 2021 11:30 PM
Hi guys,
we trying to reconnect my fathers AV5. Everything works but only the cd-i/cd/dvd wont start. I can put the original b&o interactive cd inside. But when its closes it will wait for a few seconds, nothing happend and then it re-opens.
its a 2001 model..
We would love to play a game on this old beauty. Hopefully someone can give us a tip or part that we can replace..
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sun, May 16 2021 7:38 AM
Sounds basic, but the laser faces upwards and can really catch dust. Have you cleaned it?
JamesSamuel
Netherlands
Posts 51
Hi Lee, I have tried but only with a soft cloth not with alcohol yet. Maby i need to open it up and clean it inside and look at the connections?
is does not do anything. Can it be possible that a little rubber belt is broken? I don’t know if thats even inside.
JamesSamuel
Netherlands
Posts 51
Cleaned the lens better, no result. The lens “module” moves back when i mode in manualy. So that works. But it won’t start spinning.. and reading it
JamesSamuel
Netherlands
Posts 51
I took the cd player out and took al the dust oud and cleaned is carefully. Still no differents.
here are some pictures..
JamesSamuel
Netherlands
Posts 51
JamesSamuel
Netherlands
Posts 51
Inside
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Given that you say that the draw closes, but does not spin up could mean that the controller thinks it has not closed yet.
The loader position is determined by means of two optical couplers. One checks whether the loader is closed; it does so by means of a "pin" that goes into a fork optical coupler. The other checks whether the loader is moving; it does so by means of a reflection from a gearwheel.
P115 transmits information to the CD control box indicating that the loader is closed.
Regards Keith....
JamesSamuel
Netherlands
Posts 51
Hi Keith,
Thanks for this info! Sounds very logic and possible. Where can i find p115?
JamesSamuel
Netherlands
Posts 51
I found it here in the right corner. How can i change this of make sure he is seeing the right reflection. And on what gear?
Keith Saunders
Posts 5,495
OK, you have found P115 on the CDI Loader board. The cable which plugs into that socket should go to P227 on the CDI unit itself.
Regards Keith....
JamesSamuel
Netherlands
Posts 51
Yes that’s correct. I had it removed to clean all the dust on the other side. I also found the “pin” that go’s in the fork witch is next to all the gear weels.
I don’t know what to do with this once i found it. Haha
JamesSamuel
Netherlands
Posts 51
I still don’t found a wat to fix it.. any idea’s?
Page 1 of 1 (13 items) | RSS
