I restore a Beogram 6000 that needs a few transistors replacement.
What do you suggest as modern transistor replacement for:
-BC171B (is a BC547B convenient ??)
-BC212B (is a BC557B convenient ??)
-BC183C (is a BC548CTA convenient ??)
Thanks a lot,
Sounds reasonable - but check the pinouts!
OK Thank you: I will check the pinouts !
