I've made a new purchase, quite excited really..... but I need to sell my old TV complete, which means the BS 3 has to go with it, and be replaced by the new BS3 that comes with the new TV.
Is there a chip or something with all settings that I could easily swap ???
Anyway... B&O can't come and do the install for an entire month. So I was thinking I could do some bits myself. I'm impatient.
Here is a pic of the old one, and the new one, which is in a box the size of a crate.
I guess it's either not possible.... or no one knows?
The new one is only the 65" So it's pretty much identical.
I would leave the BS3 but it will get too confusing with the warranty.... as they'll both end at different times.
Anyway... bummer. Was worth a try. Thanks for your help.
Hi lukeswiss,
Please do not forget to make a list of all PUCs you have installed on your old BS, only B&O can install them on the new BS3.
Addistionally add PUCs you probably will/may need in future. So this can be done at the same time.
hfat
Nice Didgeridoo
x:________________________
A B&O technician can take a backup of your current BS3 and restore it on the new one. But i guess that doesn't help much if you have to wait a month for the dealer to show up
Jonathan: Nice Didgeridoo
Thanks mate ! It caught on fire from some candles once, not sure if you can see the massive burn marks.
So, after the advice I've just decided to wait until B&O come. At least I know it'll be done right.
I can't believe they're booked out for a month, I guess the Global financial crisis hasn't hit Switzerland yet.....
