hi i have a problem with my beomaster 6000 type 2702 the right hand side off the unit all light bulbs work from the fm display and also p1 p2 so on.but the left hand side volume to balance no light at all ive taken a bulb from the left side and placed it on the right and it works therefore if just one bulb is dead would that cause the loop to the other bulbs not to work .or could there be cause whey the left hand side dead ? thanks
Look for a broken lead and/or leads not correctly soldered to the lamp socket tabs.
hi martin all leads soldered to the lamp socket tabs look ok
There must be a missing connection somewhere.The black leads can often break unnoticed. Try pulling them a little.
hi martin on the left hand side there areno black leads.off the 6 light top right is gray and orange top middle red and gray top left 2 gray 1 yellow .bottom right yellowand one white and green stip middle bottom1 orange2 white and green strip bottom left 1 red 2 white and green stip
Hi
Seems it is an Beomaster 6000 4 CH right?
The lightbulbs are connected in series I think , as I remember 2 in a row. Try to swap two or three new or working bulbs.
Regarding to the service manual bulbs OIL 5 - 10 are meant?
Connected via the clutch relay board PC 12 to -5 Volt and 18 Volt.
Kind regards
Christian
