I have recently bought a beosound 3200 and can not adjust the volume If I go into sound set up I get “use TV “ displayed on the screen It is a stand alone unit connected to a pair of beolab 6000 speakers only and no remote Any idea how to rectify this ? Cheer
chris
Nicely done Leo 😃👍
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 7-32 mk5 & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
+ 1. It's just a shame that the OP doesn't have a remote!
Thank you for your replies. As has been said I have no remote is there a way to solve the volume issue directly from the beo 3200 ?
I don't have a BS3200, but from reading the service manual I think you could use TEST MODE (specifically TM37) to reset to default, which will include A.OPT 1. You will lose stored radio stations and CD settings (but not A.MEM stored music).
To enter TEST MODE:
Wait 20 - 30 sec. after connecting to mains.
By means of keyboard from St.by mode: Press Display 0 2 5 8 with no more than 2 sec. between the individual enterings.
Then enter 3 7 (the Test Mode number)
From the service manual for TM37:
Default settings for sale purpose.
Option: 1
Volume: 32
Balance: 0
Bass: 0
Treble: 0
Loudness: OFF
Radio programs erased.
CD settings erased.
Timer settings erased.
After default settings the display shows DEFAULT TM ERROR.
If error occurs in TM the display will show TM ERROR.
Item-number, serial-number, type-number, master pin-code, running counter and all offset adjustments will not be erased.
^ and to leave Test Mode you press the Red Dot (power button).
Hope it works!
Thanks for the reply I’ll give it a go
