- Flere
smile and enjoy the moment
Have you checked with your dealer? They are still listed on the B&O web site, so should be available from dealers.
https://www.bang-olufsen.com/en/us/accessories/essence-remote?variant=beosound-essence-remote-white
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2 Integrated: 1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6 Control: 16x* Essence Remote • 1x Beoremote Halo
* Yes, really! 🤦♂️
laseralex:Have you checked with your dealer? They are still listed on the B&O web site, so should be available from dealers.
Flere:My dealer in the NL told me the table model is out of stock at B&O and will not be available anymore. Halo is the new choice.
What a tragic mistake. It is specifically because of the Essence Remote (and Beolink Multiroom) that I filled my house with B&O products.
The Halo is NOT a replacement, as it needs charging every few days while the Essence remotes can go a year between battery changes. When I got my Halo I already had 9 Essence remotes. Since then I've purchased two more Essence remotes, and have no plan to buy more Halos.
Sounds like I'll need to stock up on some spares from eBay.
