Hello all. Can anyone tell me how the proximity sensor works mine seems not to in beosound 2
If you approach the BS2 from the left and swipe left to right it will go to the next track or channel. If you approach it from the other side and swipe left to right you are technically swiping in the other direction, but it will stil go to the next track because it knows where you are thanks to the proximity sensor. Other than that there is no visual clue, at least not with the non Google voice assist version.
