beomaster6000 type 2702
This post has 0 Replies | 0 Followers
lotus73jps
Posts 141
lotus73jps Posted: Mon, May 24 2021 12:10 PM
hi starting to restore a beomaster 6000 type 2702 .the problem is when the unit is switched on from the on/off switch at the back off the unit the left hand side from volume to balance light up right away is that normal ? .or should they light up when  fm phono or tape is pressed thanks
Page 1 of 1 (1 items) | RSS
