BeoCenter 2300 testmode
beoservice_nl
Posts 5
beoservice_nl Posted: Thu, Feb 7 2013 1:56 PM
Hello beoworld!
Having a problem with getting into the BeoCenter 2300 testmode.
It's not the same as in the ouverture or system 2500 sound 3000.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
A Very Warm Welcome to Beoworld..
To get the Beocentre 2300 into test mode follow the following procedure:-
BeoCenter 2300 may be brought into Testmode by removing its rear panel, switching on the system into AUX mode, and short-circuit the clamper switch for two seconds; the display will now read TESTMODE.
It is necessary to switch the system to AUX before using Testmode from software version 1.3 which was introduced from serial number 11491838
Regards Keith....
beoservice_nl
Posts 5
Thank you for your quick response,
This will help alot, though it seems like the software of this BeoCenter is fried.
Or its the short-circuit fails.
During earlier repair service a few cables got connected in the wrong way resulting in short-circuiting something totally different.
To others if doors won't close (but will open) and your BeoCenter 2300 has been serviced then the chance exist that the cables from the cd clamper to the board are connected the wrong way arround. Connecting them the right way will fix this issue!
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
