Beolab2
This post has 1 Reply | 0 Followers
Nic67
Posts 2
Nic67 Posted: Tue, May 25 2021 2:39 PM
Hi I have just purchased a beolab2 sub the fuse has blown in the plug it arrived with a 3 amp fuse insitu is this correct or should it be 5 amp
regards
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Wed, May 26 2021 12:50 PM
The correct value is printed on the mainboard next to the fuse. It depends on which voltage the BL2 is driven.
It will be 4A when used with 230V and 8A when 110V is available.
Page 1 of 1 (2 items) | RSS
