Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
I'm interested to know if you can search for tracks on Deezer.
I have four and use them regularly. The only feature that's been added since launch is the ability to choose among multiple sources that are playing to "join."
I wish that support would be added for the BeoSystem 4 and for NL/ML Converters.
I've had mine some months now, and to be honest I use it less than the Essence remote that sits in the same room.
The features I use most are volume control and Touch-to-Join. For volume control I find the essence fits my hand perfectly, while the halo's ring feels less exact because I can't get my fingers around the whole thing.
I do prefer the Halo's ability to show volume level. Particularly since an essence remote that hasn't been used in a couple of days can take a moment to sync up, and I have to wait till that happens before I can actually set volume.
Touch-to-join is easier on the essence remote as well - just a simple press as I walk into the room. The halo has to wake up and then target the correct tiny button on a touchscreen without tactile feedback. (I don't ever miss the button, I just have to be much more accurate than when using the essence remote.)
I do like that the Halo displays current track - I wish they had released a version of the Essence Remote that had an e-paper display to also show track name.
The battery life in the Halo is a problem for me. I have Essence remotes all over my home - since they run almost a year on a set of batteries I can mount them anywhere. The Halo's battery dies within a few days, so it spends its life sitting on a charger - I take it off the charger perhaps once per month. I do wish the Essence had a low-battery indicator the way the Halo shows it, but I generally know the battery is low when it stops responding. :-)
> Happy you bought it?
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2 Integrated: 1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6 Control: 16x* Essence Remote • 1x Beoremote Halo
* Yes, really! 🤦♂️
Bought it 4 months ago. I have oppositie experience. Since halo I don't use essence remote anymore.
Halo has simplicity in display and control options and very intuitive. I have a q charging pad which is ideal to charge e.g. every night but still use it mobile in te room.
I got a lot of positive comments from visitors. It is surprisingly fast with almost no lag between action and response for volume and track changes. Tactile feedback on volume adjustments if perfect.
Essence has more lag due to wake up time.
I wish halo would allow google home commands (lightning scenes) and deezer track selection.
I would buy again immediately. If you consider Beolab 28 that is now build into the speaker though and might be future for all devices.
driehoek: I have oppositie experience
I'm very glad to hear this. I smile every time I look at my Halo, and I think it's a brilliant concept. I'm just not as blown away as I expected to be. I must be getting old, LOL.
I also agree with what you say about the halo's response time being better, and the tactile feedback is also great. The visual feedback on the halo is also excellent.
And yes, I wish I could talk to my Halo for google assistant commands . . . but especially full voice control over BeoLink Multiroom (source, volume, track controls) would be amazing. I hope that the new collaboration of Google, Apple, Amazon, and others on the Matter platform will allow this to finally become reality.
I feel like I should clarify my stance on the Halo. I do like the product and have no regrets buying it. I just get more value from 4x Essence Remote than 1x Halo at the same price. With the Essence remote discontinued it doesn't really matter, the Halo is the way to go.
driehoek:Since halo I don't use essence remote anymore.
Will you sell me yours? (Seriously, if you don't use yours, I'd like to buy it. I'm looking for 2 more wall-mount and one ore table style.)
laseralex:And yes, I wish I could talk to my Halo for google assistant commands . . . but especially full voice control over BeoLink Multiroom (source, volume, track controls) would be amazing. I hope that the new collaboration of Google, Apple, Amazon, and others on the Matter platform will allow this to finally become reality.
Please do not forget that the first concept that FCC ID have test it had a microfone. But the final Version from B&O had it NOT inside.
Maybe the MK II goes back to voice control.
I have a wall mount essence that I no longer need and can sell to you. Send me personal message please
The black anthracite version is now online ....
https://www.bang-olufsen.com/en/gb/accessories/beoremote-halo?variant=beoremotehalo-table-black-anthracite
Beozip:The black anthracite version is now online .... https://www.bang-olufsen.com/en/gb/accessories/beoremote-halo?variant=beoremotehalo-table-black-anthracite
driehoek: I have a wall mount essence that I no longer need and can sell to you. Send me personal message please
I did send a personal message but haven't heard back. Can you please message me on the forum or via email at yahoo.com - my email address there is eealexhay. (Email address split to prevent harvesting by spambots.)
Thanks!
any new functions?Is the volume wheel only for volume control or does it allow scrolling through lists / menu items? Like a gigantic jog dial, that would be a great idea for nowadays big music libraries.
For those familiar with Halo operation, two questions:
1. From Halo directly, can a user initiate the “Timer” function? For clarity, this is the function within the B&O app that allows a user to tell systems, among other things, “Go to Standby after x minutes.” (I use this to listen to music as I fall asleep and set my bedroom system to turn off automatically after 10min when I’m asleep.)
2. From the Halo directly, can a user manipulate the “Alarm” function for a given device as it operates within the B&O app?
Thank you!
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Just thought I’d give this a bump again in case anyone has familiarity with the above. :)
Huge thanks, Brian!
Big bummer. Seems like good functionality to have…
Have the Halo since 1 month.works perfect for me. Since I have converted most of my ML to besound core and added some Beolab 28's it works fine.
Just one issue. On one core system I have connected a pair of Beolab 9. When I put this core on standby the speakers do not go on stand by the speaker light is still green. If I shut the core of with the BEO app the speaker go in stand bye (red ligth).
Does somebody know what to do?
The recent silent upgrade to support BeoSystem 4 has really added its usefulness to me. I've reminded B&O that added support of the NL/ML Converter would hugely bring in control of all legacy products. E.g., BeoSound 9000, BeoVision 10, BeoSystem 3, etc. Control of all of those devices added by just adding support for the converter.
beojeff:NL/ML Converter would hugely bring in control of all legacy products.
1. Bsys 7000 - BLC integrated to BV11 - Halo sees the Bsys 7000 sources and can start the sources
2. BS9000 - BLC integrated to BS Shape - Halo sees BS9000 sources; start, next, previous do work
3. BS3000 - BLC integrated to BS35 - Halo sees BS3000 sources; start, next, previous do work
So........ some were already available some are improved
Carolpa: beojeff:NL/ML Converter would hugely bring in control of all legacy products.\ 1. Bsys 7000 - BLC integrated to BV11 - Halo sees the Bsys 7000 sources and can start the sources 2. BS9000 - BLC integrated to BS Shape - Halo sees BS9000 sources; start, next, previous do work 3. BS3000 - BLC integrated to BS35 - Halo sees BS3000 sources; start, next, previous do work So........ some were already available some are improved
Playing NL/ML sources as primary or secondary linked sources in a local list has been available since the launch. What's I'm talking about is direct control of the NL/ML Converter with its connected speakers.
beojeff:Playing NL/ML sources as primary or secondary linked sources in a local list has been available since the launch. What's I'm talking about is direct control of the NL/ML Converter with its connected speakers.
This you wrote:
"The recent silent upgrade to support BeoSystem 4 has really added its usefulness to me. I've reminded B&O that added support of the NL/ML Converter would hugely bring in control of all legacy products. E.g., BeoSound 9000, BeoVision 10, BeoSystem 3, etc. Control of all of those devices added by just adding support for the converter."
makes it confusing, because I read more than just the controll ot the BLC as an active speakerlink.
