No app connection to my BeoLab 50s
Lasse K.
Posts 6
Lasse K. Posted: Thu, May 27 2021 9:52 PM
Hi there,
I just cannot connect to my Beolab 50's anymore.
The app says it is waking the BL50's up but I cannot get to them.
When I connect through the "products" entry, I get an error saying "We cannot reach your product". Even when they are playing.
How can I reconnect without resetting everything?
Problem has been posted before but I couldn´t find the answer. Could anybody help me?
Lasse
MaxH
Posts 126
MaxH replied on Fri, May 28 2021 9:30 AM
First thing to try is to power cycle everything . . .
Lasse K.
Posts 6
Lasse K. replied on Fri, May 28 2021 9:53 AM
Sure thing! Didn't work, though ...
Lasse K.
Posts 6
Mikipidia
Posts 2,169
Mikipidia replied on Fri, May 28 2021 11:38 AM
Second thing, is get an ethernet cable from your router to the master speaker. If there is any network config issue you can fix it while wired.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Lasse K.
Posts 6
Lasse K. replied on Fri, May 28 2021 3:11 PM
Tanks! Will give it a try tonight.
Lasse K.
Posts 6
Lasse K. replied on Sun, May 30 2021 10:36 PM
Tried it tonight. Didn’t work, unfortunately. When BL master is wired to LAN it indicates a strong connection (status LED network solid white). But in this state I can’t find it on WLAN and access through my iphone. If I disonnect the LAN cable and do a network reset I can find the BLs on my phone. (At least 6 times out of 10, that is.) The the app sometimes finds the BLs and I can enter wireless setup. Sometimes setup even seems to be successful but when I try to access my BLs - product cannot be found. It‘s just so damn frustrating. Spent 6 hours now on this. Don‘t see what I could change or try different. I‘ve done a complete factory reset now a couple of times but still haven‘t resolved it. (So now I even lost my calibration settings.) Connection behaviour just seems so erratic. No clue what to do ...
Mikipidia
Posts 2,169
Mikipidia replied on Sun, May 30 2021 10:55 PM
Are you sure it's the speakers at this point? Because, correct me if I am wrong, but even when wired the app doesn't connect 4 out of 10 times???
btw, is everything up to date software wise? speakers too? which SW are they running?
Page 1 of 1 (8 items) | RSS
