Hello,
Gotten a nice 26 beovison 8 for the gameroom.
As expected it was sticky. Much more then I ever would tought.
I really like the sound/design so I want to clean it up.
Any advice how to proceed? I did a small bit with 70%alcohol and looks ok.
Would love to dismantle it also so I can put some elbows in it while cleaning.
Any advice would be very welcome!!
Greetings Bas
Nobody a idea??
Just continue with the 70% alcohol - be patient and enduring.
If you know how to dismantle (and put together again), that would help.
Beware of putting any pressure on the screen, since there is no glas there, you might harm the panel. MM
