Beolab 5 and PIN code
This post has 10 Replies | 0 Followers
frog
Camberley UK
Posts 624
frog Posted: Mon, May 31 2021 11:19 PM
no, it isn’t what you thought when you read the subject title :)
I just bought a pair of beolab 5s with serial number 179XxXxXx - and according to beotech, the speakers should have pin code protection - but I just can’t activate it (software version 2.61).
the manual states << << STOP while the speaker is on standby and it should alternate flash red/green. But nothing happens. Is there something I’m missing to be able to activate the Pin system?
Jack
Poland
Posts 30
Jack replied on Tue, Jun 1 2021 8:34 AM
The PIN code protection has been introduced from serial no.: 17xxxxxx.
Due to PIN code has been introduced in BeoLab 5 there are two Back-up suitcase variants:
3395223 for BeoLab 5 without PIN code protection
3395234 for BeoLab 5 without PIN code protection, US/CDN/TWN/JPN
3395224 for BeoLab 5 with PIN code protection (expected release week 46-2003)
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Tue, Jun 1 2021 10:25 AM
All the BL5's with software 2.xx or 3.xx have the pincode option. The first mk1 with 1.xx have not.
Personally I hate the pin protection. It's far from user friendly. Touch the topplate and giving it remote instructions. Then there has to be some sound to confirm etc. Sometimes there is, sometimes (mostly, and when you're doing the wrong sequence) there is not.
With almost every disruption from power, you need to reprogram.
frog
Camberley UK
Posts 624
frog replied on Tue, Jun 1 2021 9:17 PM
Yes, that’s my point - software version 2.61 - serial number 179xXxX - but no pin code!
Beobuddy
Posts 3,972
The only way to get definitive answer is to connect the servicetool to retrieve its identity. Perhaps you’re consequently doing the wrong sequence? Right option setting?
frog
Camberley UK
Posts 624
frog replied on Tue, Jun 1 2021 9:39 PM
Ah, I don’t have that software, but I’m just on l.option 0 (default) and from standby press << << Stop. Then nothing….
can’t think I’m doing anything wrong.
Beobuddy
Posts 3,972
Beobuddy replied on Tue, Jun 1 2021 10:02 PM
Do you touch the topplate when you use the remote?
frog
Camberley UK
Posts 624
frog replied on Tue, Jun 1 2021 10:17 PM
No, if I try that, it goes into calibration mode.
Beobuddy
Posts 3,972
Beobuddy replied on Wed, Jun 2 2021 10:01 AM
Slip of the mind, should be pressed after pressing << << stop.
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SPEAKERS/BEOLAB_5/EN-BeoLab5.pdf
frog
Camberley UK
Posts 624
frog replied on Thu, Jun 3 2021 4:33 PM
Yes, that’s what I followed. Strange I can’t get it to work…
frog
Camberley UK
Posts 624
Page 1 of 1 (11 items) | RSS
