Can I attach the above to my Beovision - 11
Connecting the device should not be a big problem.
Just plug it in to a free HDMI input port and configure this (the BV11 will probably assist you there).
However controlling it will probably only be possible with the original remote control.
I don’t know the device, but these solutions mostly bluetooth (and not ir) for controlling.
There are some code converter solutions out there, which might allow for the use of a PUC-entry (in order to control it with the Beoremote/ir).
Maybe someone else knows if these may work with this specific device.
