BeoNut since '75
If you buy a BV11/V1be sure to get the 'new Beo4'
If you already have one, ask the dealer to upgrade your 'old Beo4' with the new PCB.
If you have bought it not too long ago, he might even upgrade or swap without costs.
Greetings Millemissen
Just checked, the latest version of v1 does support appletv command, older commands (net) have gone.
the command web is a synonym for dtv. Appletv seems to be a new command.
hfat
hfat:Just checked, the latest version of v1 does support appletv command, older commands (net) have gone.the command web is a synonym for dtv. Appletv seems to be a new command.hfat
Youtube and web TV are not available yet for source definition. N.Music and N.Radio are not available, the only audio source available ist Radio, which plays radio stations via sat tuner. The Media command brings up al list of available dlna servers.
So with the new and updated version of the Beo 4 it is NOT possible to access N.Music and N.Radio? That means it is useless for e.g. Beosound 5 users?
Sorry there is a missunderstanding: N.Music and N.Radio are not available on the V1.
Why not?
If you connect it via NL/ML-converter (to a audiomaster) it would act as any other videomaster.
hfat:Sorry there is a missunderstanding: N.Music and N.Radio are not available on the V1. hfat
Millemissen: Why not? If you connect it via NL/ML-converter (to a audiomaster) it would act as any other videomaster.
Yes, that's true. But I use the V1 as a stand alone product, at least so far, maybe I change with v.Opt 6 of NL/ML-converter, It is great to have an AUDIO source like RADIO mapped to sat tuner. You simply start RADIO and browse through the radio channel list. After some time with no IR interaction the screen goes off. If you use Beo4 you have EPG and all other features other TV channels offer.
So could think of having the option to map N.Radio, N.Music to some sources of home networt, if used as stand anlone product, just like the new YOUTUBE command maps to an App of the Smart-TV source.
You often have N.Radio and N.Music as a source when you have a BM/BS5-combo.
In that case it would actually be smarter to to rename these sources to Radio and CD in the menu of the BS5 - for direct-access on Beo4.
Of cource you need the NL/ML-converter for that!
N.B. Not everyone has access to radiochannels via satelite.
Could you give us some/more examples of the use of the mapping of the new sources in the list/rv-menu?
Does the command 'YOUTUBE' opens the YouTube-app from standby....?
Does it actually make life easier for a NB11/V1-user?
hfat: [But I use the V1 as a stand alone product, at least so far, maybe I change with v.Opt 6 of NL/ML-converter
I don't think that is possible. The V1 and BV11 can not act as a link-TV in as in the "old" master link setup.
DoubleU: I don't think that is possible. The V1 and BV11 can not act as a link-TV in as in the "old" master link setup.
Not now, but in future I think it will be possible. Have a look here http://archivedforum2.beoworld.org/forums/p/4392/39634.aspx#39634
Here in austria it is quite common to have tv via satelite.
The youtube command is not yet available on the v1, so I can give you no example how it works. I'll tell you as soon as it included in a new SW release.
