Hello out there, hope you can help? I’ve recently acquired the above mentioned turntable and need advice on what to connect it to for best playback?
I would like to think that your Beogram 1200 would be a good match for the Beomaster 1200,and leave you with something to hook up to your speakers . Which,by the way,are an unknown quantity at the moment .
What speakers are you running?
Are you running the Beogram with a CD, cassette deck-and what speakers?
Noel.
