Recommendation for a setup
This post has 9 Replies | 0 Followers
antonyo
Posts 5
antonyo Posted: Fri, Jun 18 2021 7:21 AM
Hello BeoWorld!
I have a following equipment:
LG OLED77G1
BeoLab 18 & 19
Palatial BOP LCR66 - front
Celestial BOC86 - surround
Celestial BOC62 - 2nd zone
How would you connect all of this? AV receiver, BeoSystem, …?
1990
Posts 521
1990 replied on Fri, Jun 18 2021 9:28 AM
You have many options! A recommendation would depend on your answer to these three questions:
1) Which remote do you want to use? The LG remote or BeoRemote One or Beo4/5/6?
2) If you want to stream music, do you want the LG to remain off or can you live with the screen coming on and using the LG as your AP2/CC/whatever endpoint?
3) How do you want to use your second zone?
antonyo
Posts 5
antonyo replied on Fri, Jun 18 2021 10:06 AM
1. I like the design of BeoRemote One very much. What I know about it is that it can replace all the remotes for AV system, but I don't have much experience with it. And I can live with LG.
2. Better if it’s off. Also I like Sonos app for iPhone for streaming services.
3. Second zone is for music in dining most of the time.
Millemissen
Flensborg, Denmark
Posts 14,680
I find it hard to give any advices for this without knowing more about your wishes/requirements.
I you are thinking about sound from the LG TV, your problem is that you have no ‘AV receiver’ with the described setup!
I assume that you want that, since you describe the speakers as the channels of a ‘surround setup’.
(What did you do before the LG TV, and how were the 18/19  used previously)?
antonyo
Posts 5
antonyo replied on Sat, Jun 19 2021 8:00 AM
Everything is new here, bl 18/19 wasn’t used before.
I had a recommendation to buy Onkyo TX-RZ740, but there’s no supply in my region for a long time. Also Marantz SR5015, but there’s problem with connecting xbox x. And BeoRemote One is a good idea.
antonyo
Posts 5
antonyo replied on Wed, Jun 23 2021 3:42 AM
Any ideas?
antonyo
Posts 5
antonyo replied on Fri, Jul 2 2021 12:19 PM
1990
Posts 521
1990 replied on Fri, Jul 2 2021 3:07 PM
Okay, here is a suggestion. I'm not sure where you are located and if you can source the components:
- Almando Multiplay Surround Switch with Wisa. This is both a surround decoder and an AirPlay 2 or ChromeCast endpoint. Connect the BL18 and BL19 via Wisa and the Palatial + Celestial via an amp (e.g. BeoLink Passive or BeoAmp 2). If you want Sonos, you can add a Sonos Port.
- Drive your second zone through an amp of your choice and add a Airport Express if you want AP2, CC Audio if you need CC or a Sonos Port.
vlohjr1
Posts 553
vlohjr1 replied on Fri, Jul 2 2021 8:24 PM
antonyo:
Hello BeoWorld!
LG OLED77G1
BeoLab 18 & 19
Just buy the harmony portion?
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Jul 2 2021 8:54 PM
This is what I would get:
1. Beosystem 4 as AVR
2. Sonos Connect Amp for second zone
Using Sonos with B&O as well.
Ralf
Page 1 of 1 (10 items) | RSS
