BeoLab 8000: replacing filer capacitors > which replacements are recommended?
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER Posted: Fri, Jun 25 2021 4:10 PM
I need to replace the filter capacitors in my BeoLab 8000.
These are C9 & C10 on PCB2/Power Supply.
Their values are: 4700uF, -20+50%, 63v.
I have had the recommendation to keep the same value, but only use a bit higher voltage than the original.
By the way, I need to replace them in a BeoLab 8000 with these serial numbers:
  • 1342xxxx
  • 0942xxx (older)
Question:
  1. Which type/brand of capacitor is recommended to use as replacement?
  2. Is there any difference in filter capacitor between these two serial numbers?
  3. Suggestion for a webshop is appreciated.
Dante
Sao Paulo - Brazil
Posts 163
Dante replied on Sat, Jun 26 2021 3:07 AM
https://www.newark.com/cornell-dubilier/381ll472m063a032/cap-4700uf-63v-alu-elec-snap-in/dp/54AH2153
The original capacitors are 85 or 105 oC rated?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Jun 26 2021 7:38 AM
KolfMAKER:
May I ask why you need to replace them?
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sat, Jun 26 2021 11:03 AM
Thnx Dante.
The originals are 105 oC.
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sat, Jun 26 2021 11:06 AM
Thnx Martin.
I have two with hum and hiss. Had an extensive search for the source of this problem.
Next week I get help with measuring through the electronic circuits. But the suspect looks to be these two capacitors.
Since I am a bit in a hurry finishing my projects with these BeoLabs, I already prepare the next step if needed. In this
case finding a good source for the right replacement material.
So your suggestions are welcome.
Page 1 of 1 (5 items) | RSS
