Core and Beolab 18 problem
This post has 5 Replies | 0 Followers
Techno
Posts 11
Techno Posted: Fri, Jun 25 2021 5:28 PM
Has anyone a view on the following problem? I cannot get the bass or treble control to work when using the B&O app on my iPad. (B&O app and iPad ios software latest versions. New Core hard wired to speakers. Streaming music via Bluetooth/Apple airplay to Core). The music from the speakers sounds ok but I cannot tweak it to my particular taste.  Any help appreciated. Cheers. Techno.
Gary
Dublin, Ohio
Posts 108
Gary replied on Fri, Jun 25 2021 7:49 PM
If you cannot adjust the bass/treble sound of your lab 18's via SETTINGS through the last updated B&O app software update 3.15.2, try downloading the previous version (3.14.2). The newest version presented me with similar challenges. Until 3.15.2 has all of the bugs fixed, I would stay with 3.14.2. - Hope that this helps.
Millemissen
Flensborg, Denmark
Posts 14,680
The 3.15.0 is a beta version (the latest)…for testers.
The 3.14.2 is the regular version from the app store.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Jun 25 2021 9:37 PM
Techno:
Which version of the app please ?
Gary
Dublin, Ohio
Posts 108
Gary replied on Fri, Jun 25 2021 9:58 PM
If you are a TESTER and have downloaded the 3.15.0 version, try deleting this version. Go to the App Store and download the 3.14.2 version.
Millemissen
Flensborg, Denmark
Posts 14,680
Gary:
I have a better idea…
If you are a tester, you may know that you can roll back to a previous version……which you can find in Testflight.
No need for deleting anything.
But ok!
This previous version happens to be the same that you get when you download the regular from the app store ;-)))
Page 1 of 1 (6 items) | RSS
