Hi
My BS9000 I believe is experiencing laser issues.
It just plays the first track off a CD then moves onto the next CD. Sometimes it takes a bit before it will play the CD (sounds like the laser is trying to focus).
If I skip to track 2 of a CD it will then play the CD ok.
Tried to clean it but it doesn't seem to have worked
Also I believe a new laser would be better for longevity of the unit.
Anyone know or can recommend someone who can service and replace the laser in or around the Sheffield area.
T.I.A
Mark
Hi, the only laser service in the UK, I know is FM-AV Repairs in Exeter. You could contact with them and inform us on your experience
