Whatever happened to all Peter Pans postings? I cant seem to find any,- just me? Settings perhaps?
(Almost) all of his posts is in this one single thread of his own:
Peter Pans Hjemmebio, - interface - tips & tricks. - (beoworld.org)
Thanks Martin.
I already found that one. However as mentioned I actually see NONE of Peters post. Everybody else but not Peters, which (knowing Peter ) makes for many pages with just a few or just one posting?
Yes, I can see that.Apparently he deleted his posts.
Aparently Peter Pan just wrote a post (this is what he mailed me on my request).
Why can’t we see that post - it even appears in the overview that he posted.
I doubt it... more than 2000 postings in many different threads would take quite a while.... ?
Peter Pan account is back working correctly, nothing was deleted or altered.
Go HERE to his thread
Regards Keith....
Keith Saunders:Peter Pan account is back working correctly, nothing was deleted or altered. Go HERE to his thread
trackbeo: Keith Saunders:Peter Pan account is back working correctly, nothing was deleted or altered. Go HERE to his threadLooks like he --or some malefactor with the account info?? -- is deleting & has locked(?) all the posts in that thread back thru Dec 25 2020, including the post herein above. What a pity.
His posts have NOT been deleted, its just you currently cannot see them. The following is a screen shot of the last one from Peter before today
Keith Saunders: trackbeo: Keith Saunders:Peter Pan account is back working correctly, nothing was deleted or altered. Go HERE to his threadLooks like he --or some malefactor with the account info?? -- is deleting & has locked(?) all the posts in that thread back thru Dec 25 2020, including the post herein above. What a pity. His posts have NOT been deleted, its just you currently cannot see them. The following is a screen shot of the last one from Peter before today
There must be something fishy here - see screenshot.
The question is….why are his posts locked (since April this year appearently)…even in his ‘own’ main thread?
I did not know that you can lock your own posts yourself - and it would not make any sense either.
Keith Saunders: posts have NOT been deleted, its just you currently cannot see them.
Same effect for everybody else, wouldn't you agree ?
You cannot lock your own post under normal circumstances. Only a moderator can do that..
Whilst you and all other members are getting the message that all the posts are deleted, it's not actually true. From my admin account I can see all of Peter's posts perfectly.
The issue is how all these posts became locked and initially hidden.
It is starting to look like a software bug in the forum. I am still looking into the matter..
Thanks Keith - I am sure many beoworlders will be pleased to see the posts from Peter Pan again.
Millemissen: Thanks Keith - I am sure many beoworlders will be pleased to see the posts from Peter Pan again. MM
I am planning to load the backup server with a backup copy of the Forum from yesterday, so I can try and see what may have happened.
This will take me a while, so please don't expect Peter Pan's thread to be back working today..
Hmm,
funny i can see all popst from Peter Panm in the thread Keith mentioned: https://archivedforum2.beoworld.org/forums/t/444.aspx?PageIndex=1
His first post in the thread and also the last post from 16. June 2021 6:17 AM including all pictures.
Maybe try to force reload of the page in your browsers: <CTRL> + <F5>
Ralph-Marcus
I can also see them now. Two hours ago I couldn't.I suppose Keith found out something.
Dillen: I can also see them now. Two hours ago I couldn't.I suppose Keith found out something. Martin
I can confirm that I have found the problem and fixed it..
The problem was in the Microsoft SQL Server which made the system think 22 posts were locked and not available to users.
Thanks Keith for the good work.
I reloaded the same page that was in my screenshot above and….now I also see the posts (they are in ‘his’ main - Hjemmebio - thread).
However, some of his posts in other threads - from this year - still appear as ‘deleted’……so not quite fixed yet!
Maybe those will soon appear too.
Keith Saunders:I am planning to load the backup server with a backup copy of the Forum from yesterday
Not sure that is going to cut it,- this situation has existed for more than a week, properly two. Besides Peters reply in this thread still shows up as deleted.
BEOVOX141:Not sure that is going to cut it,- this situation has existed for more than a week, properly two. Besides Peters reply in this thread still shows up as deleted.
It turns out that the problem has existed since 23rd December 2020
trackbeo:all the posts in that thread back thru Dec 25 2020
Keith Saunders:It turns out that the problem has existed since 23rd December 2020
If that truly is the case, and I was the first to react.... Then the content cant possible have been missed by anyone but me... I wonder if all the Pantastic LG ranting had any influence?
BEOVOX141: Keith Saunders:It turns out that the problem has existed since 23rd December 2020 If that truly is the case, and I was the first to react.... Then the content cant possible have been missed by anyone but me... I wonder if all the Pantastic LG ranting had any influence?
Peter Pan himself had indeed noticed it….as he told me.
Personally I did not notice, since I can read much the same in his posts on several danish forums.
For ‘some reason’ he did not react - he probably resignated because his english isn’t so good that he would contact Keith/the moderation team directly.
P.S. No comments from me on your presumption, that ‘the Pantastic LG ranting’ might have had any influence.
