Beogram8002 120V version on 240V
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Thu, Jul 1 2021 7:08 AM
Hi All,
gone through some older posts referring to that pronlem:
it is apparently not recommended to use a step-down transformer running a 120VAC/60Hz transformer at 240VAC/50Hz because the bipolar capacitor is different and could cause incorrect phasing for the motor circuit apart from perhaps other issues ?
4C1 = 27uF for the 120V/60Hz , 4C1 = 39uF for the 240V/50Hz version.
if my step-down transformer supplies the correct tap voltage for the 120V/60Hz transformer could I partially counteract the frequency problem in changing to the cap used to the one with 50Hz mains frequency ?
meaning, still using the step-down transformer but replacing the 27uF cap with a 39uF cap ??
Thank you so much  for your advice🤩
ALF
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Jul 1 2021 8:01 AM
Yes.
And ideally, you should also replace the rear carriage rail. It's different too.
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Thu, Jul 1 2021 1:33 PM
thanks Martin,
changing the rear carriage rail will probably prove to be more difficult than changing the capacitor. ?
see what I can do.
best solution would of course be finding the Mains-correct transformer ?!
regards
ALF
Dillen
Posts 13,191
Dillen replied on Thu, Jul 1 2021 1:45 PM
ALF:
thanks Martin,
see what I can do.
regards
ALF
I agree.
Page 1 of 1 (4 items) | RSS
