Hi guys
My Monent is dead from last week.
No reaction to reset or battery dranin or any suggestion from forum.
Did any from you try to repair screen?
thanks for any helpππ.
Hello,
it happened to me twice and the only solution is to get it to the dealer...
HI
thanks for reply. Do you know what has been problem or issue.?
Inside is battery, one custom pcb and one complete tablet form unknown surce made in China.
look's like on custom board is SW all other is yust tablet.
Any of you have simelar problems.What if only battery has gone bad?
How could i know that?
Is it 100% that needs new board inside?
Can i test somehow to see what is error?
thanks for any expert replyπππ
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Thanks Miki...and..great Yotube channel.ππ
