Hello all, new to the forum, glad to have found it.
I have a Beogram 6002 that works fine except, the tonearm doesn't seem to be sensing the start of the record. Pushing play will make the tonearm move all the way to the end of the record and then return to park position.
The light sensor is illuminating normally. Before I drag it out to the bench, I'm curious if this is a common or known fault and, if so, is it repairable? I'd rather not tear the thing down just to find the parts I need are unobtanium!
Any advice welcome!
