Hi everyone,
I have a BeoVision Avant 55NG, and I cannot gain access to google play to download any Apps, as my email account details are never recognised.
Have tried setting up different email accounts to make sure all the details are correct, but none of these have worked. Seems a ‘user error’ problem but has anyone else had the same, and is there something I can do to fix this?
Tom
Hello!
did you try to enter your account at the Android Menue from the main menue?
best regards Elmar
Hi Tom,
Chiming in with a suggestion that perhaps you could check on first
Looking at my BV14 which is also the same 'chassis' as your BV Avant 55 NG I am able to log on to the play store.
When i got my TV actually i reinstalled the OS as i found the TV was coming on and off and since then I have had no issues and found the TV to be rock solid, even if it is an older Android version.
The bit i wanted you to check on is when you press on your BeoRemote One:
> home
> settings
> Android Settings
This will bring up the Android Settings Menu which looks a bit different to other menus
Scroll down till you see the 'personal' section, do you see your google account there?
Also under Location, is it using your location?
Dear Tom!
fine that it is working now! The options downloading further apps are really bad… you would definitely need a extra box like apple TV; but without account data you can not update the Basic TV Apps which in my case was absolutely needed to run the software without crashing every 5 seconds
