That is something, that quite a few beoworlders have asked for.
It is not possible with the current version.
Maybe there will be a version 2 (or another beoremote) with this feature at some point…..or maybe not!
Tom: ........ but becomes useless in the dark!
I don´t think so.
The BR1 BT version has 2 strikingly increased lines " to feel " the most for daily used keys in the dark.
When you has a good memory than it is no problem. The most keys are under "List" so you only learn this location
Sure would be nice to have a button backlight but when in this way the design and the feeling is gone ... noooooo way.
Never change a running system
