Connecting American Beolab 1 speakers to Beovision3 32"
This post has 5 Replies | 3 Followers
PeteMacBeo
Posts 7
PeteMacBeo Posted: Sun, Feb 10 2013 4:14 PM
Hi To everyone, I am just wondering if someone can help me,  I am loooking at buying a pair of Beolab 1 Speakers which have come from the states and I would like to know If I can plug these into my Beovision 3 32" or would I need adapters, for the power or connectors for this to work.
I would also like to know if the Beolabs are renowned for any particular problems that I should look out for before purchasing.
Thanks In Anticipation Peter
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Feb 10 2013 5:01 PM
No problem attaching them but you will need to change the power supply. You could use a mains transformer but much neater just to get your dealer to change the module - pretty sure this is a fairly common procedure.
Beolab 1s are good - sometimes criticised for being a little bass light and steely at the top end - I think they sound very good!
Peter
PeteMacBeo
Posts 7
Hi Peter Thanks for that,
how much would you think it would cost to change the module on them?
Thanks Peter
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sun, Feb 10 2013 7:02 PM
Love my bl1's . Not aware of any thing to look out for in the pre-loved world except visual damage to polished body , foot and fret.
Lets know how it goes for you.
Foxtrott
Vienna, Austria
Posts 821
Foxtrott replied on Mon, Feb 11 2013 2:41 PM
Hello Peter,
One (more or less obvoius) detail: Your BV3-32 must be equipped with the (optional) Dolby-Module so that you can connect the Beolab1 via Powerlink to the BV3.
A BV3 without the Dolby-module (like mine) has no connectors/sockets for external speakers, but AFAIK the Dolby-module can be retrofitted if necessary.
Cheers
Foxtrott
"The first thing we do, let's kill all the lawyers."
William Shakespeare, Henry VI, Part 2, Act 4
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Feb 11 2013 3:11 PM
PeteMacBeo:
Thanks Peter
Not sure - Lee might be able to advise
Peter
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
