After having refoamed a couple of cx100 and cx50 I was ready to do the same with a pair of cx40. BUT... I can't remove the screws from the speakers. They seem to be very long and I can screw them about 1 cm and then they are stuck.
What's the trick?
/riis
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Most likely the padding material curling up around the screws inside.The screws are very long.
Can't you take off the backsides and have a look inside ?
I never heard of CX40, must be C40 (what's the difference anyway, CX and C speakers?).
Not sure what your situation is but one trick is to put a side-cutter between the screw and the CX40 frame and while turning it lift the screw a bit up using the side cutter. I'm sure this could have been explained in less words but hey, my English...
Brengen & Ophalen
