This came up before and I know most are recommending against but is anybody actually running a BL11 with the BL4?
My dealer thought of it as a viable option. I haven't had a demo yet but was wondering if anybody did and actually decided to go for it?
Not looking at other recommendations, I know how great the BL4000 are but sometimes other factors matter too, like size & available color options
Cheers
JK
I don't have an answer for you but am wondering why people were recommending against it?
Jeff
I think when questions about BL4 pop up general notion is that the BL4000 are in the same price range and a much better value.
My angle is, I have the BL4 already they might be too weak for the Bl11. Its for sure an uncommon combination.
Ah, I get it, I had misread BL4000 instead of BL4! Like you say, you have them so might as well see if it works.
