Swapping screen on BV 10 to antireflective
This post has 5 Replies | 2 Followers
Hiort
Sweden
Posts 2,895
Hiort Posted: Thu, Feb 14 2013 9:08 AM
I´m considering to change the glass on my BV10 40" to antireflective.
I thought I was saving some money when I did not order the antireflecive glass when I first bought the set, but I have regretted it ever since.
It´s not so very expensive to buy a new glass (but still a lot of money).
Heard somewhere that there is a setting in the service menu, where you tell wether you have antireflective glass or not, but I´m unable to find it. The picture settings need to be adjusted with the antireflective screen, and this would be an easy way to to that.
Does anyone know?
bayerische
Ekenäs, Finland
Posts 4,770
Is it really possible to change it afterwards?
Too long to list....
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Feb 14 2013 10:00 AM
bayerische:
Yes it is. However the whole glass front is replaced including the aluminium frame. It´s only 4 screws under the screen that needs to be removed. Then the whole glass and frame is pushed slightly upwards and removed. I´ve seen it done several times when I had some problems that a service guy needed to fix.
bayerische
Ekenäs, Finland
Posts 4,770
bayerische replied on Thu, Feb 14 2013 10:26 AM
Cool, well I guess it makes sense to be able to change it.
Expensive?
I have the Antireflection screen, I'm just curious.
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Feb 14 2013 12:46 PM
bayerische:
Expensive?
Price for the antireflective screen  (40") is around 810 eur here in sweden, I recall that it was about this price to have it factory mounted from the beginning.
This is what the BV10 looks when screen as well as the panel is removed. It´s smart that the TV can be serviced without being removed from the wall bracket.
This is the screen waiting to be put back again.
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Feb 14 2013 1:08 PM
I found what I was looking for in the service menu:
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
