Beosystem 2 questions.
Beeblebrox
Posts 4
Beeblebrox Posted: Tue, Jul 6 2021 8:58 PM
Hi, I have aquired a beosystem 2 and a beovision 4-50 and have it working with my old Philips MFB speakers and all seems well watching DVDs. I understand it can control a set top box if it’s in the list that one of the menus brings up, I have aquired a Panasonic box that is in the lest, is there anything else I need to make this work from the BEO4? I ask as I have noticed that there is an IR out which sort of makes me think there beosystem two takes the signal from the beo 4 and converts it to control the Set top box and transmits this from the IR out by an led diode?
i also have an ouvature which I may also connect to this system, will it make the ir eye I have redundant?
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Jul 8 2021 8:55 PM
Yes, you need an IR cable.
https://www.ebay.de/itm/Bang-und-Olufsen-IR-Blaster-/154494188679?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0
For example this one.
Has to be 3,5 mm to IR.
The IR part needs to be stick with adhesive tape on the ir receiver of the set-top box (outside).
Easy job.
For the Ouverture you need a masterlink cable.
All speakers attached to the Beosystem 2 and you can here CD Sound via the TV speakers while the TV stays off.
Enjoy!
Ralf
Beeblebrox
Posts 4
On the subject of the STB itself, I’ve been looking at the Panasonic examples, and from previous experience with their VCRs have found that their remotes works across a wide age range of their products, does the same apply to the pair STBs? My reason for asking is the  TU-CT200 is standard definition and not HDMI, and although the Beovision 4 is not 1080p it’s is capable of 720p so I would like to use a later STB
Page 1 of 1 (3 items) | RSS
